Bridge slots http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=47454 |
Author: | cablepuller1 [ Tue Mar 15, 2016 5:00 pm ] |
Post subject: | Bridge slots |
This has been probably been covered before but what's the thoughts on slotting the bridge and using unslotted pegs Just read it improves sound and response as more contact ? Here's pic I just seen ![]() |
Author: | Colin North [ Tue Mar 15, 2016 5:07 pm ] |
Post subject: | Re: Bridge slots |
Not so sure about the sound and response, but certainly a big improvement in longevity of the bridge plate and pins. Lottsa posts on this. |
Author: | Rod True [ Tue Mar 15, 2016 5:28 pm ] |
More posts on this than you can shake 100 sticks at.... most are in full agreement, unslotted pins good, slotting bridge/plate good. |
Author: | Jeff Highland [ Tue Mar 15, 2016 6:09 pm ] |
Agree with the "less damage to bridge plate". Disagree with the concept that more contact= more energy transmission. A common belief but unsubstantiated. |
Author: | Barry Daniels [ Wed Mar 16, 2016 10:40 am ] |
Slotting a bridge is good. I do it all the time. The photo also shows slots on the saddle which is a bad idea. At least I had bad results with that. |
Author: | Tim L [ Wed Mar 16, 2016 12:06 pm ] |
I think a lot of people slot and ramp their bridges. Not sure how many slot their saddles for improved contact. Could certainly give you more of a break angle when you are using a wider saddle blank for intonation. At least that's what I see in the picture in the OP. Tim |
Author: | cablepuller1 [ Wed Mar 16, 2016 12:27 pm ] |
What do you guys use to slot the bridge..my nut files are to big for this task |
Author: | kencierp [ Wed Mar 16, 2016 1:04 pm ] |
Dremel tool with dental bits. You can make an efficient tool using a very fine tooth saber saw blade/s (at least 22 tpi) I found the saw sold specially for this purpose way too course and actually useless. |
Author: | DennisK [ Wed Mar 16, 2016 1:13 pm ] |
cablepuller1 wrote: What do you guys use to slot the bridge..my nut files are to big for this task Zona saw keyhole blade, and knife style needle file. Remember that if you want the guitar to support medium gauge strings, to make the slots big enough for them. Conversely, narrow slots are a nice way to hint to future owners if a guitar is meant for lights only ![]() |
Author: | Hesh [ Wed Mar 16, 2016 2:07 pm ] |
Along these lines if you like Tomastik strings slot bigger.... they have very wide windings..... ![]() ![]() ![]() PS: One more thing: With instruments with the bridge design being marginal for break-over angle slotting the bridge, top and plate can add break angle. |
Author: | bftobin [ Sat Mar 19, 2016 6:49 pm ] |
I reshaped some jigsaw blades on a grinder. They've worked well for me. Brent |
Author: | Ken Jones [ Sun Mar 20, 2016 8:46 am ] |
Barry Daniels wrote: Slotting a bridge is good. I do it all the time. The photo also shows slots on the saddle which is a bad idea. At least I had bad results with that. Ervin Somogyi has had pretty good results with it... Sent from my iPhone using Tapatalk |
Author: | Barry Daniels [ Sun Mar 20, 2016 8:52 am ] |
I don't think the slotted saddle is what makes his guitars sound good. More likely the super thin tops and bracing. But I invite others to try this. Take one of your nice sounding guitars and make a slotted saddle for it and compare them. The one time I did this (on a Breedlove) the slotted saddle literally ruined not only the tone but also the volume. It was dramatic. I would be interested in hearing if other builders have the same results. |
